Air to Air Vs Air to Water Heatpumps. Now closing the gap.
Because our summers are becoming hotter and will continue to do so, the heat pump is a great way to keep your house cool whilst your gas boiler becomes an expensive water heater
No works both ways, either takes heat from inside the house or from the condenser outside
So, it's a hybrid air to air heat pump with a hot water cylinder attached. I've finally got it! The room is heated by hot air. But it also has a water circuit for the cylinder.
You don’t understand energy costs
And he’s also got a gas boiler and radiators for when his big hair dryer can’t cope
I was going to rip it out but thought might as well just leave it as a redundant system.
