- Joined
- 7 Nov 2023
- Messages
- 22,058
- Reaction score
- 14,318
- Country
exactly, air to air heat pump.If so it's an air to water heat pump. HWM was talking about air to air. Wasn't he?
He was talking about air source heat pumpsIf so it's an air to water heat pump. HWM was talking about air to air. Wasn't he?
It is confusing isnt itOMG. I'm so confused! This is what he originally said:
'So now air to air systems are closing the gap to air to water systems by adding heat recovery to a water cylinder for hot water. Still cheaper than air to water systems and far superior. Mine is superb and saves me a fortune.'
The only real difference is air con.OMG. I'm so confused! This is what he originally said:
uses the liquid refrigerant which takes on heat through the refrigeration cycle and transfers it to a coil in the hot water cylinder.So how does the heat in heating mode get to the hot water cylinder?
The only up side is in summer.uses the liquid refrigerant which takes on heat through the refrigeration cycle and transfers it to a coil in the hot water cylinder.
take a read of this which explains it better than I am.So how does the heat in heating mode get to the hot water cylinder?
heating in the winter, we just open our windows when it gets too hot insideThe only up side is in summer.
No works both ways, either takes heat from inside the house or from the condenser outsideOnly in cooling mode, surely?
They don’t produce enough heat for a decent sized uninstalled house.heating in the winter, we just open our windows when it gets too hot inside
