UFOs
The RWR on here won’t be able to tell the difference.
Its hilarious that they actually believe not only in alien anal probes and alpha centaui cowboy builders, but that they think there's going to be a massive reveal of information about it.
Did anyone see the strange object in last nights starship launch seen in space on the live feed looked like a UFO to me.
I was unable to identify the object that appeared to be flying.
Any links to this, I find UFOs fascinating
At about 4 o clock as the starship slowly turned there was a big object that came into view from behind the starship. This was at 7.24min and was in view until 7.45 as the starship turned and the camera mounted on the grid fin moved it went out of view.
The timings I have stated are +T lift off it appears stationary in space / earth orbit
the large object is really obvious. If you look at the feed in high res you can see it has structure, it is not a lens flare it is not moving or spinning like a lump of ice flying off the craft would behave.
Looks like this one is a little harder to debunk or explain away.
