1 Gang electrical socket to 2 Gang
15 May 2009
West Midlands
Can one Gang electrical socket be changed with a 2 Gang socket? All sockets of the house are on one trip switch (if that makes any difference)
It is in a house I have bought and by the looks of it, it was recently re-wired (New trip fuse box and cables seem new)
Thanks guys.
Just wondering would both sockets be able to handle high load. For example, 4 Gang extension leads on each socket. (I'm not planning on doing this, I'm just wondering if it will be safe to do so?)
It should be okay, as the fuses in the extension lead and in the plug tops will protect the equipment and flexes from over load as will the trip on the MCB.
But is this a case of needing more outlets? if it is, have you consider installing some more?
It’s just that their is only one single socket in the room. I think one double will be enough. I mentioned 2 (4 gang) extensions as an extreme case. But on average, I don't think more than 4 devices to be plugged into the sockets.
What sort of devices?
If you mean computers, tellies, table lamps, etc, then there will not be a problem with any likely quantities you could encounter in a normal house (at least as far as load is concerned - there may be a problem with having too many computers on one RCD trip switch)
If you mean room heaters, water heaters, kitchen or laundry appliances, or you are doing hairdressing at home with multiple blow driers on simultaneously, then these are not suitable to be supplied from multiway extension leads or multiple socket conversions.
