1 Pipe Heating Sytem
7 Mar 2015
Yorkshire
One Pipe CH System
Our home has a one-pipe system and I know the best thing to do is to change it to a 2 pipe system. At this time it's just not possible.
It would be possible to alter the pipes so there is a one-pipe circuit heating the upstairs and another one heating the downing stairs circuit. Both of these would return to the boiler separately.
I am not doing this work, our usual gas engineer would be doing the work.
I would really appreciate the reader's thought on this idea.
20 Jul 2005
Nottinghamshire
Usually the 'one pipe' is run in as a single loop of pipework throughout the house with all the radiators sat atop it. Two separate loops would be required to split upstairs and downstairs. Depending on how the loop is currently run, you might be able to split it into two separate loops fairly easily, or you may have to re-plumb most of the system, in which case the work would be similar to converting it to a two pipe system.
