1000m Door Opening
12 May 2016
Need sime advice please
I have a exact 1000m door opening including the lining.
I want to fit doors in ther. Iv looked around the best size i can get is 533mm wide door shaving over 33mm is a lot??
Please can i any one give advice what i can do would like glazed doors
Shirley shome mishtake, don't you mean 1000mm?
33mm is far too much. Many doors have only a 6 to 10mm adjustment allowance. TBH a 1000mm masonry(?) gap sounds like the opening for a single 926mm wide DDA door, or do I have the opening size wrong
If you really want doors for this you may need to look for doors at 1981 x 457mm (6ft 6in x 1ft 6in) and build out the lining, but TBH they aren't that common
Bit shy on info , where in property is opening , how will it be used ? Fully glazed ? 1/2 glazed? One door ? Two doors ? Panel and door? Room for sliding doors?
You need a minimum of 600 for a door in regular use at 500 they would have to be left open defeating the point of having doors.
