10mm microbore and 15mm mixing
16 Jul 2009
Hull
If you have a full system on 10mm microbore. Would it be ok to have one rad piped in 15mm to the rad valve. It would be the bathroom rad. Wanting to use 15mm as the pipes exit through a stud wall so would give a solider job on the first fix.
Wouldnt look too out of place with the rest of the rads being on 10mm? Or cause a problem.wi it heating up faster/ quicker?
Is just for stability as the plasters are tending to bend the 10mm storks
