In conclusion, thanks to your help… it worked…
Well done and thanks for sharing the outcome
I figured it was likely a 1ch board…
My concern for wanting to swap both wires was based on believing you had two completely different audio sources - if both were differential amplifiers, commoning the negatives could have been a problem.
As it is, your sources are exactly the same - you've just added resistance - commoning the negatives will be fine.
If you still wanted to play, your two channels give you the option for 3 settings - if you swap the module back to 'toggle' mode:
A and B off, the default, full volume
A on, B off, reduced volume through resistor.
A on and B on, no sound...
(This is of course purely theoretical, ignoring any legislation that may exist for the prescribed volume of pedestrian warning noise, in electric vehicles!
Out of curiosity, what is the resistance and wattage of the resistor you have chosen?
