12v drop bolt to loft hatch - wiring help please
To add the standard "drop bolt" should be vertical not horizontal.
So a magnetic lock should be better and a bit cheaper, but use a 1amp PSU and keep everything out of the way so it cannot be switched off.
And dont forget the battery back up.
Thers no need to prove that you suffer the dunning kruger effect.
What are you proving by writing the above then? :wink: :) :lol: :D
There's no need to prove that you suffer the Dunning-Kruger effect.
I quite like the idea on certain levals, if only because there are a lot of crap loft-latches out there that are either ugly, hard to make an air tight hatch, or both. However I too would be looking at a remotely released pull-cable operated latch rather than a mag latch.
Daniel
