Hi All
Just to start off, my understanding of electric wizardry is reasonable but basic.
I have a brewery that I am upgrading in size and power. Here's the rough electrical plan... forgive me if I use the wrong terminology.
By my reckoning my current setup draws around 23A (about 11.5A per element) and this system has proved to be stable and robust.
Now I would like to upgrade my elements to 3.5kW each. Again, my reckoning says that the 30A parts of my setup will handle this fine because the max current being drawn at any one time will be a smidge over 29A... however each individual element will pull 14.6A which exceeds the 13A rating of both the socket outlet and the fused spur switches.
My first question (or series of questions... will this simply not work? will the fuse blow immediately or is there a built in tolerance?
My second questions... if this will not work, what are my options?
Thanks!
- Starting at the fuse board, there's a 30A fuse.
- Then a 30A rated cable supplying power to my control centre.
- Amongst the other gubbins I've got on the control centre I've got two fused spur switches (13A). Each of these switches controls remotely, via 30A rated cables, a socket outlet (one outlet per switch... I've chosen this layout because switches on my control centre are more easily accessible than the socket outlets themselves - the outlets remain switched on at all times and their power is controlled by the switches on the control centre).
- My elements, which are 2.75kW each are then plugged into the socket outlets using standard domestic 13A fuses.
Thanks!
