15mm pipe bending help
looks good enough, now to practise with neater looking end feed fittings .
As a DIYer I don't do enough soldering to become proficient. Still using Yorkshire fittings to ensure enough solder is used. Most of the soldering I've done lives under floorboards so it doesn't really matter what it looks like.
Once the copper pipe is painted it won't be that obvious
did you add a bit of solder when you blew the joints if so that is basically like doing an end feed joint
Looks good. I'll never understand people that think a mottled emulsion looks better than a bare copper pipe.
I agree the copper pipe does look nice, apart from the joint and the surplus solder. For all the other radiators I've replaced, I've used white pipe covers from Screwfix, which give a very clean finish, much better than painted pipe, but it won't be possible with these bent pipes.
The other issue with exposed copper is oxidation!
They will dull but they won't go green any time soon.
Only plumbers think end feed looks better, most people couldn't give a toss, they just see a bit of copper pipe going into a radiator.
Glad you think so you sound like you would be happy with chunky compression as well.
But an awful lot of customers will mention the slightest thing they see.
Same as they also say oh that is really neat and tidy pipework , thanks
