Hello all,
Just a quickie, if there is 100 amp three phase supply, which then supplies three flats via switch fuses. Can 16-mm t/e be used with an 80 amp switch fuse if wired in correct zones or is 63 the maximum allowed. i was led to believe that 63 was recommended
