17th edition CU
8 Dec 2005
Cornwall
Fitting a new board in a bungalow
one ring circuit
one lighting "
one cooker "
one immersion "
two panel heaters "
Best way to connect?
Split with 2 RCD's?
Cheers
Depends how they are installed.
My opinion is it is better to keep the lights on their own, possibly via RCBOs. Maybe worth looking at splitting the lighting circuit into two also.
The rest you can do as you like, probably better between 2 RCCBs
Also please note that this work will be notifiable to your LABC under part P of the building regs.
splitting the lighting circuit is not really viable without major work.
maybe just keep the lights, cooker and panel heaters on one rcd
and the sockets, other panel heaters and immersion on the other
Conventional split, RCBOs for lighting and socket outlets, and everything else on RCD side?
yea i guess. i suppose the cost wont be too different
when you lose the one rcd and replace it with two rcbo's
TBH for 5 ccts I'd go with RCBO's as the split RCD boards are very large in comparison.
Comms
That link gave RCBO's @ £30.99 a go I'm getting MK ones for £21 at moment.
Comms
Yes I picked some Wylex rcbos up thismorning for £24.99
comms, are these CPN boards any good? where can you get them?
how can they be so cheap? works out less than a tenner
for each rcbo plus the board and main switch
