Can anyone help with the above, i want to be able to switch a lamp in the living on and off by a switch on the wall. per a electrics book i have it says that i can do this with a 2 amp lighting circuit with 2A round-pin unswitched sockets.
please can you confirm that my understanding as follows is correct, if i run 1.5mm 2core and earth from the CU (from a 6A MCB) to the light switch on the wall and then run 1.5mm 2core and earth from the light switch to a 2A round-pin unswitched socket on the wall and if i wanted to i good run another cable to more sockets finishing at the last one, as a radial circuit. this then would enable me to control the light via the wall switch.
if this is not correct or there is a better way of doing it please let me know.
max
max
