We are trying to install new kitchen lights on a 2 gang switch we are unsure what wires go where. its two lights tht are controlled by a double switch thing and atm nothing works please help
the red yellow blue and earth are part of a 2 way lighting circuit maybe for the lounge the other will be for your kitchen light unless they switch of and on from another switch aswell tell me where your at with this so far
the only lights this switch operates are the one in kitchen tho the red yellow & blue wiring does seem to go from wall switch to one light alone then another set of the same coloured wires goes from that light to the other but they still operate independently of each other in the past. this does mean i am not sure which wires connect into the common, L1 or L2 port on light switch or in the live or netural connector on lights, tho it does have spare socket on lights for extra wire
