2 light cables into switch, single light, want to cap off
17 Jan 2008
London
Hi there,
I've had a look to see if something similar has been posted previously, but can't see anything specific.
New property and the bedroom has a double gang dimmer switch. There is only 1 light in the bedroom (and this is controlled by one of the switches).
Wanted to change this to a single dimmer as 2 switches are uneccessary - and I keep pressing the wrong one!
When opening up the light switch box, see two light cable wires going into the double-gang dimmer. So presumably the bedroom used to have 2 lights controlled by 2 switches.
Question is - how can I install a single dimmer and cap off the second cable wires safely?
I'm guessing the second cable is live as it has been wired to the switch. Can I just use a plastic junction box (or similar) and some insulation tape? Not sure there'll be enough space behind the plate to accomodate this though.
thanks.
Just to check, those two cables do definitely go to separate gangs and not both to the same gang?
are there any spare sockets for bedside lights maybe, that the 2nd switch could control ?
'fraid not.
Not sure why someone had once installed 2 lights, as it's fairly small room (3m x 3m). Maybe the second switch powered a fan or something(?)
Anyway, it appears the previous owners couldn't be bothered to find a solution so just put a 2-gang switch on instead.
you can just terminate the unused cables in some choc block terminal strip inside the existing back box.
Thanks, do I just attach Earth, Live and Neutral wires to one side of the strip without any additional insulation?
Yes, but you'll also need to put a little bit of green/yellow sleeving on the bare 'earth' wire.
Kind Regards, John
Wouldn't connecting the CPC(earth wire) to the earth terminal be desirable?
I thought about suggesting that (which is probably what I would do), but decided that it was slightly more complicated for the OP, and I couldn't really think of a particularly compelling reason for doing it - do I take it that you disagree?
Kind Regards, John
Not certain. That's why I formed it as a question.
It depends where the cable goes.
I suppose if there was a reason to connect it, it will be earthed at the other end.
I'd like to connect them all to earth but can't tell from here.
Not certain. That's why I formed it as a question. It depends where the cable goes. I suppose if there was a reason to connect it, it will be earthed at the other end.
As I said, I did consider this question. In the end, I decided that it's no different from, say, the CPC in a cable going to a Class II item - i.e. all one needs is to find somewhere to 'park it'. As you say/imply, if it's a 'live' cable, teh CPC should be connected at the other end.
As I said, that's probably what I would do - but probably only through 'habit'. I can't really think of any particular benefit in deliberately creating 'earth loops'.
alex_diz: I don't think you should worry about these subsequent exchange between EFLI and myself. You can either do as you said, and put all three wires into one side of a connector block or, if you'd prefer, and if there is an earth terminal in the back box (or on the switch plate), you could connect the earth wire (with G/Y sleeving) to that, and the other two (live and neutral) wires to a connector block.
Kind Regards, John
Kind Regards, John
OK - thanks John (and everyone else who responded)
