- Joined
- 12 Aug 2006
- Messages
- 41
- Reaction score
- 0
- Country
Hello again
Can someone please explain what a 2 pole switch (with 3 mm contact?) is ? The reason I'm asking is that I've just had 2 ceiling fan lights installed by a qualified electrician. The fans work OK but it in the instructions it says specifically that these fans should only be used with a 2 pole switch. I mentioned this to the sparky when he started installing them but he said something along the lines of :-
a) You don't have that option.
b) It's not really necessary.
I need to get this cleared up! Why if it says in the manual "WARNING - can only be used with a 2 pole switch" did this sparky feel it was OK not to? What is a 2 pole switch anyway?
Cheers
Alex
Cheers
Alex
