    Dismiss Notice
2 quick questions
Discussion in 'Plumbing and Central Heating' started by teddyb, 13 Feb 2012.
  1. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    Hi
    1. Is it necessary to have boiler off when freeing the pin in a TRV?
    2. Would a squirt of WD40 help to keep the pin free?
    They may be daft questions, but important for me :eek:
  2. Sponsored Links
  3. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    1-No
    2-Yes
    • Thanks Thanks x 1
  4. D_Hailsham
    D_Hailsham
    18 Oct 2007
    10,587
    Thanks Received:
    1,343
    Kent
    Country:
    A silicon-based lubricant is better as the chemicals in WD40 can cause the seals within a TRV to disintegrate.
    • Thanks Thanks x 1
  5. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    Thanks. Being new to this bit of DIY, I felt it best to check. :D
  6. Sponsored Links
  7. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    Having taken the head off, I find it is broken. Part of the plastic which grips the brass nut on the valve has crumbled and the black 'sick' doesn't move when the dial is turned. The good news is that, without the head on, the radiator is now hot :D . Does anyone know if it is possible to buy just a replacement head part, or do I have to get in a plumber to replace the whole valve and drain down the system?
    As always, thanks for all advice and help. :):)
  8. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    Of course, I meant STICK not sick. :oops:
  9. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    Most of the leading brands(Peglers, Drayton, Honeywell among others) will supply heads only.
    • Thanks Thanks x 1
  10. tryitandsee
    tryitandsee
    23 May 2006
    866
    Thanks Received:
    43
    Southampton
    Country:
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
