2 Qu's-fixing to chipboard & laying same direction a joi
8 Aug 2008
Berkshire
Hi all, been trawling through the search engine and just wanted to clarify a couple of things.
I'm installing a solid oak, 18mm thick, 140mm wide planks from Howdens.
They are going into a room 6m by 4m and on to suspended chipboard.
The general advise seems to be to float the floor over an underlay - am I right? If so can someone recommend me an underlay and adhesive and where to get them from. I have seen some 3mm in Homebase for £1.85 a metre but aware that they normally overprice and under quality!
Also my joists go in the same direction as I would like to place the planks (ie parallel)
Am I OK if they go the same way?
Finally I also have some stairs (3) to deal with - I assume this is not a problem with floating. The stairs are at 90 degrees (proposed) to the (proposed) direction of plank.
Thanks,
Presuming your suspended chipboards floor is load-bearing you can lay the floor length ways.
You need at least 16mm expansion gap
board is about 20mm thick and has had carpet on it for about 10 years with no probs . Every shop i call is telling me to nail it - am i really ok to glue and float it?
You cannot nail on to chipboard: it'll 'explode' due to the force and angle of the nails.
Glue T&G's and float.
chipboard is horrible rubbish. pull it all up and throw it away.
18mm T&G hardwood is sufficient for a floor on its own
you can use a ply layer underneath if you feel the need.
I considered it but would be a big job and the current chipboard goes under all the walls etc which I would not be able to do with ply.
The chipboard has been ok for prolly ten years or so would really rather not.
I'm still a bit nervous about floating it!
Is it worth me 'splashing out' on the fibreboard insulation pads at £2/m from Wickes? Are there cheaper suppliers? Google search not being too helpful...
Just bought bog standard 'no nonsense' wood glue from screwfix - I assume this will be adequate?
