Currently have a 2 gang 2 way light switch working fine. One switch is 1 way, 1 switch is 2 way. Swapped it for a 2 gang 2 way dimmer switch, very careful of getting com to com, l1 to l1 and l2 to l2. Brilliant, powered up, both dimmer switches turn on, turn off, and dim, brilliant I thought, then tried the light switch (non dimmer) at the other side of the room and this will not turn on or turn off the light.
After much umming and arrrring, I put the old switch back on to see if I'd made a mistake with the wiring. Old switch works fine both sides of the room. So I put the dimmer back on again, but the original problem still exists.
Any ideas please?
Any ideas please?
