2 way dimmer
9 Sep 2006
I am trying to wire up a new two way dimmer switch. I have 2 cables coming in, each with a bare earth cable, a black and a red. My switch also has a covered earth (green/yellow) coming out of it.
Each side of my switch has an L1 L2 and a third hole with ~ and an arrow going diagonally through it.
Any help on how to wire this up would be greatly appreciated!
Thanks all
you have 2 cables. one goes to one switch, the other one goes to the other switch.
red to ~
black to L1
You must sleeve those earth wires with g/y sleeving. Is it a metal switch? if so, the best thing to do is to connect the earths to the face plate. If not, connect them to the metal backbox terminal.
Thanks a lot for that! My lights now work, but the dimmer does nothing at all?
Not even turn the lights on and off when you press the buttons in?
filly, how was sthe old 2 gang switch wired did you make a note?
It was just an ordinary switch before and I did not make a note! I thought the instructions with the switch would be good enough! How wrong was I??
The lights turn on and off just fine but the dimmer does nothing at all!
What type of lights are they? Are they normal 60w bulbs etc, halogen etc?
I take it the dimmer is suitably rated for the amound of candle bulbs on each circuit, I would suspect the dimmer switches are broken.
Beats me! I reckon I will just make do with lights that work on a fancy new switch. Thanks for your help on getting them to work as it will be dark soon!
Cheers guys
How many 60w lamps are turned on from each dimmer switch? What does the rating on the dimmer switch say, i.e. 40 - 250w or 40 - 400w?
I have 3 60w bulbs off each switch! It says 60 - 250w and 200 - 250v-
My best description......
1 solid back plate
3 holes at top, 3 holes at bottom
top 3 labelled COM A, 1 way B and 2 way B
botton 3 labelled COM B, 2 way A and 1 way A
I can also tell which ones were used as The screws are still out,
On the top COM B and 1 way A were in use
On the bottom COM A and 1 way B were in use
Sounds like everything else is in order, my 10p is on the dimmer switches are to blame.
