Dear All,
I've just been reading the following post which says that it's no problem to use a 2 way pull cord switch on a 1 way circuit:-
https://www.diynot.com/diy/threads/can-i-use-a-2-way-switch-on-an-1-way-circuit.278152/
I've installed a replacement switch, which was only sold as a 2 way version. The instructions say that a 2 way can be used as a 1 way.
However, when I pull the cord, it requires 2-3 pulls before the light comes on! It works, but it's a bit retarded. It always goes off with the first pull.
Is the switch going On L1, OFF, On L2, OFF, then back to L1 again to create this situation?
I would have thought the connection simply goes back and forth.
NB - Without drawing to assumptions, I also changed the ceiling rose for a triple spotlight fitting. Switch wire identified, only connected to L on the fitting. All 4 other red lives grouped together in terminal block, same with the Neutrals, and Earths. Then twin and earth used to connect from the fitting to each group of Earths and Neutrals, with only the Switched Live connected to L. Essentially, same as in this video:-
Any thoughts?
Cheers!
Any thoughts?
Cheers!
