2 way switch connection
29 Nov 2006
Cornwall
Have been looking at the 2 way switch connections in the FAQs and have confused myself a little. :confused:
I am changing a 1 way (1 gang) switch to 2 way (1 gang) the new second switch is just at the other side of the wall, so all I have to do is drill through and connect up.
I have two brown wires in the existing switch and was thinking that all I would have to do is run one of these wires to the COM on the replacement switch and one through the wall to the COM on the new switch and then connect L1 to L2 and L2 to L1. but I didn't see this way of wiring a 2 way switch in the FAQs, have I got it wrong.
Any advice or confirmation would be welcome.
Duff
no, absolutely correct..
it's called 2 plate wiring.. and it IS in the wiki..
it's the top 2 drawings in this picture.. ( left shows 1G switch, right shows 2G switch )
That way of wiring switches is usually referred to as 'the conduit method'
It is unusual to wire domestic switches like that, just because conventional circuit layouts make it easier to link two switches with a three core and earth cable.
There is nothing wrong with doing it like that though.
From our ever knowledgeable wiki:
Thanks for the quick responses guys.
I looked but didn't see, cheers for the confirmation, much appreciated.
Duff
