I'm fairly certain the answer to this is no... because you wouldn't be able to wire the common, but I thought I'd see if anyone had any bright ideas.
I've got an existing light which has a single switch cabled as a 2 core live/switched live. Is there a circuit possible which will add another switch to make this into a 2-way setup without changing the cable to the existing light switch (which is buried in a wall)?
Cheers.
Cheers.
