2 way vs 1 way switch
5 May 2006
What would happen if I used a 2 way switch where a 1 way light switch should be used?
no
a 2-way switch can be used as a one-way.
many people just keep 2-ways in van stock to save the bother of carrying two sorts.
Use the COM and the L1 terminal, which is usually also marked "1 way" as well :wink:
Just use the C or common for one wire and L1 for the other.
If you used C and L2 it would work but with the switch in the opposite positions.
If you connected your wires to L1 and L2 it wouldn't work.
Neither scenario would be dangerous.
