Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Coincidence - look @ the drain run for a blockage - probably fat as you`re in London - the whole system has tons of it - from individual bedsits to the Embankment sewers uneducated public
I tought of blockage too.
But the toilet wich is on the back of this one is working fine (the back flow has happend from this one).
All in total it looks like the water pressure is not enough to open the lid on the abr until the level reaches the rim of the pan.
and than it is only enough to keep it open a little so the water has to squeeze through.
I can only think that the spring is too hard/strong . which makes it usefull when installed on a vertical connector.
Of course my one is horizontal (back outlet).
