"Which" carried out thorough long term tests,
When did you last test the light output and start-up time of modern CFLs?
I am getting a bit confused here. We use 500w floodlights around other properties and they do a good enough job. We switch them on when we want them and switch them off when we don't.
But aren't these "CFLs" a) less bright and b) slow to start ? When we need bright lights we need them instantly and not wait for them to warm up. Or do these have different characteristics to the ones used inside domestic properties ?
If this is a temporary solution then go ahead and use 500 watt lamps as you originally suggested - they will be fine. If this were a permanent solution then a low energy solution would be highly appropriate.
Thank you Sparkticus. This is indeed a temporary installation. I have this telegraph pole on the site that I can place a couple of the bog-standard 500 watt lamps on the top of and I want to be able to control the on/off from within the static that I am living in whilst the new place is being built.
I am throwing intruder beams all over the place so I know if we have visitors at un-sociable hours and it would be handy to light the site up so that they don't trip over anything and hurt themselves.![]()
That would be 1KW about 4.5 amps. 1mm would be fine from a current carrying capacity but this is outdoors right? You should really be using something better protected.
So to conclude, I need 1mm cable but because it's outdoors I need something more substantial than twin with earth ? What should I be asking for/using ?
make sure the circuit feeding the light includes a 30mA RCD.
Given it is a temporary solution, 6 months - 1 year - Assuming that no one is going to step on or trip-over it then I would use this:
http://www.tlc-direct.co.uk/Products/CA0dot75R3.html
In general this cable has a current carrying capacity in the region of 6 amps. The two 500 watt lamps in parallel will draw roughly 4.3 amps.
Make sure you protect the cable with a 5amp fuse and make sure the circuit feeding the light includes a 30mA RCD.
Surely should be using hi-tuff outdoors?
Hi-Tuff ? Could you explain please ?
Why?
