    Dismiss Notice
2009 Countax C800H 4x4 Deck lift problems.
Discussion in 'In the Garden' started by ademco, 21 Jul 2021 at 7:50 PM.
  1. ademco
    ademco
    28 Dec 2007
    52
    Thanks Received:
    Herefordshire
    Country:
    Hello there, I have recently purchased a Countax C800H 4x4 mower with known issues. The main problem Is that the electric deck lift is broken. I have checked the lifting ram by applying 12v to the correct pins in the plug and can get it to lift and lower by changing polarity. Have just fitted a £100 new Deck height module Of which made no change to the problem, still doesn't move with the dial on the dash. Now the dial is £200 for some reason as it's only a tiny part. Is it likely that it's the dial at fault? Can it be tested in any way?
  2. Sponsored Links
  3. lostinthelight
    lostinthelight
    11 Feb 2016
    2,960
    Thanks Received:
    574
    monmouthshire
    Country:
    Don't know if this is any help
  4. Burnerman
    Burnerman
    7 Feb 2008
    22,861
    Thanks Received:
    4,451
    Northumberland
    Country:
    Have a look at the circuit board behind the dash and inspect for any burnt components - and there is a fuse or two.
    Hell of a bit of kit, this one!
    John :)
Loading...
Related Threads
  1. d000hg
    7
    6,141
Share This Page
