Hi
Am installing a new bathroom and would like opinions on the size of pipe to use. The tap is a 2 valve thermostatic mixer (one valve for bath and one for separate shower). I have taken 22mm hot/cold feeds to the tap.
Question 1 is: on the shower and bath they both have 1/2" bsp connections. Should i therefore just run 15mm from the tap outlets (3/4"bsp) or shall i size down as near to the bath and shower as possible.
2: The shower has a straight connector into the hose outlet which comes out of the wall. Can i just attach a bend with a compression joint and then run the pipe down the wall or would i be best using a wall plate elbow (as below).
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=100122&ts=64460&id=17416
Thanks in advance!
Forgot to say, system is combi boiler mains fed.
Thanks in advance!
