22mm / 3/4" straight through wall plate flange
23 Feb 2026
Why doesn't anything like this exist:
...but which accepts a 22mm inlet pipe and has a 3/4 thread for a large garden tap? All I can find in this size is wallplate elbows, but I want a straight-through-wall type.
With or without the copper pipe pre-soldered doesn't matter.
Everyone would usually just have a 15mm feed with a 1/2". For a larger tap I'd just use a 22mm to 3/4" compression or end feed on the end of a 22mm pipe and then just wrap and mortar it into the wall leaving the tail.
View attachment 408561View attachment 408562
Would be a bit nervous about hanging heavy buckets , knocking it etc if it's just hanging off the end of the copper.
This doesnt look too bad. Would a 22mm compression nut fit 3/4" BSP male?
That's why you would embed it in the wall and then mortar it in, with just the female section protruding it should stand up to any weight, just like the wall plate would.
