22mm to 1/2" tap valve flexi-hose?
8 Oct 2005
London
Hello
I've been looking everywhere for the flexi-hose in the title, but it doesn't seem to exist?
My old bath has 22mm cold and 15mm hot pipes. My new bath has a mixer tap with 1/2" legs.
Is the only alternative to fit a 22mm - 15mm reducer on the the cold, then use a 15mm - 1/2" valve flexi-hose? Will this affect the flow rate?
Cheers for any advice.
Hello
If your hot water is fed from a combi boiler or megaflow cylinder it will make no difference. But if the hot water is fed from a water tank in the loft you will need a 22mm pipes to a 3/4" hot water tap.
Cheers Spraggo.
It's a combi-boiler, so I just need to get a reducer for the cold feed then?
