Hi
A new bathroom fan I've brought IS NOT SELV.
It has the Square in Square symbol, and is designed to work in the loft.
It has an IPX4 rating.
MY QUESTION
As this is not a SELV unit - can I safely install the fan in the loft in a vertical position
so it vents out of a roof cowl AND have the bathroom grill within the shower cubicle area.
I ask because when the grandchildren come over and/if they decided to start spraying
the shower (coming off mains pressure/combi boiler) up into the grill/vent leading up the
aluminium ducting - would this still be safe?
I wanted to install the fan within the cubicle (not enclosed at the top - regular height) so
that the fan extracted X amount before filtering out into the rest of the bathroom.
Or should I fit the fan outside of the shower area - the fan is rated at 187 m3/hour
( 52 Litres per second) Airflow Rate.
Advice would be welcome.
Thanks in advance.
MY QUESTION
Thanks in advance.
