hi,
got a question about my upcoming 2391 practical.
one of the tests is an earth fault loop impedance test where you have a socket mounted on a block off wood( to plug your tester in) along with 3 switches.
the socket plugs into a 230v socket(via a flex cable and 3 pin plug) to get its power and the 3 switches put different values onto the socket where you plug your tester in.
one of the switchs gives a situation where no earth is connected and i was told that you should not proceed with the test in this situation, can anybody explain why?
and also my megger mft1502 automatically starts testing when voltage is detected so surrely it will start immediatelly when i hit the switch with no earth,thus failing me?????
please help, am confused!!!
