    Dismiss Notice
2391 practical
Discussion in 'Electrics UK' started by alex28, 11 Jul 2008.
  1. alex28
    alex28
    6 Aug 2007
    27
    Thanks Received:
    Country:
    anyone got any pictures of fault board scenarios? got 2391 practical on monday and its just the fault board I need to do, passed the other 3 but not being an electrician am struggling to see all the faults on the fault board
  2. Sponsored Links
  3. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    They are quite obvious faults, you are just doing it as you would an initial verification i.e. look at the conductors, where they are going etc. Make sure the conductors are in the correct connections i.e. polarity. Look at the main bonding, see if it is up to scratch and continuous along its length. Look for RCDs for socket circuits. Check the conductors are tight, not too much insulation stripped back. Check the cables not bent sharply. Check the fuse board schedule is correct and present.
  4. alex28
    alex28
    6 Aug 2007
    27
    Thanks Received:
    Country:
    Cheers will revise the initial verification stuff in GN3
  5. ppuch1
    ppuch1
    8 Aug 2006
    91
    Thanks Received:
    3
    London
    Country:
    And check for identification of conductors. i.e. colour ident sleeve on any live conductor (switched or otherwise) Strappers colours etc.
  6. GaryMo
    GaryMo
    3 Jul 2007
    4,134
    Thanks Received:
    162
    Manchester
    Country:
    ...and the old favourite - 2 t&e cables on their side clipped together in one cable clip!
  7. pompeygit
    pompeygit
    2 Jan 2008
    243
    Thanks Received:
    4
    Hampshire
    Country:
    And a socket labelled 'outside socket' that has no IP rating, polarity of main tails
  8. Sponsored Links
  9. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    Think it was labelled for outside use when I did the exam, however it didn't have an RCD (back in the days of the 16th edition) so got noted down. Now of course, if it is to the 17th edition then all normal sockets should be on an RCD.
  10. skenk
    skenk
    23 Oct 2007
    1,094
    Thanks Received:
    81
    Glasgow
    Country:
    I had a damaged cable-entry grommit on mine, just a slice through it you couldn't see it unless you pushed it around.
  11. alex28
    alex28
    6 Aug 2007
    27
    Thanks Received:
    Country:
    Some of the things are hard to notice-sliced grommet could be difficult to pick up-on the last test they had 1.5mm wire feeding 2.5mm wire but that wasn't a fault?
  12. alex28
    alex28
    6 Aug 2007
    27
    Thanks Received:
    Country:
    also are the mcb's supposed to be type B? cheers
  13. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    Why would it be? The 2.5 might be for where the cable is passing through thermal insulation or high ambient etc. It could just be for volt drop, have installed 25mm² tails onto a 70mm² cable for VD before.
    Depends on what the load is really.
  14. ColJack
    ColJack
    16 Feb 2007
    11,795
    Thanks Received:
    410
    West Midlands
    Country:
    mine was general things like..
    no earth sleeving on one of the T+E earths
    no earth wire from the armoured cable banjo
    non continuous wire on the bond from board to water and water to gas ( two cut ends under the earth clamp screw )
    32A breaker on a 2.5 radial
    missing blanks from the knockouts in the board
    neutral from RCD protected circuit in the non rcd neutral block
    earths in wrong terminals on earth block
    twisted T+E
    mains polarity wrong on the incommers ( so all the breakers were then on the neutral )
  15. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
