The Ring doorbell PSU supplied with some Ring doorbells, or available separately from Ring, fits a single DIN module way. Though there are arguments saying products not type tested by the consumer unit manufacturer shouldn't be fitted in the consumer unit. Ring also make a matching surface mounted enclosure for their 24V PSU that can be mounted adjacent to the consumer unit.
It seems the power supply for the Hager CU Product Dimensions 85 mm (H) x 70 mm (W) x 58 mm (D) so 4 module wide, Part Number ST314 so you will need an independent enclosure.
I do agree one can break the rules and use a third party transformer, the ST301 is two module wide, but 8 and 12 volt.
Din mounted transformers don't always fit as there designed to fit a section with no bus bar.
Some Ring bells are DC and others AC.
Argos where I got mine sold the new AC door unit but only sold Ring DC plug in power supplies
