Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
3 core + Earth, 1.0mm2 (from screwfix probably), what size cable clip fits this? All cable clips seem to be 2 core + E. So does one use a clip for 1.5mm2, 2 core + E or will a 1.0mm2, 2 core + E clip fit?
Just make sure you get a good quality one with a "stud" on the underside that helps to hold the cable in place. 2.5 T+E is thicker than 1.5 3C+E, but approximately the same width - some cheapo clips don't hold 1.5 3C+E cable firmly.
You may even find a stockest that has proper 1.5 3C+E clips but most don't bother stocking them because most sparks don't bother buying them.
