Hi All
Stuck this on the plumbing website as I thought there would be an answer. My system runs cold for all outlets from the tank, including 2 electric showers via a Salamander pump. This means if you are having a shower or using one of the other cold outlets there is no loss of pressure. The Combi feeds the hot in the kitchen, two bathrooms and cloakroom. System has been working great.
Spanner, we have now had a loft conversion which means an extra bathroom. I know you can not run 3 electric showers of a household 100amp mains. If I use a thermostatic shower the pressure from the hot is not going to be there, I have run a simulation with just 1 hot feed on.
This can not be an uncommon problem, so what is the answer, priority board / get a three phase supply. The latter is going to be expensive.
