My advice would be to utilise single phase before your domestic wiring. Having three phase in a domeati installation is pointless. Furthermore it is likley to cost more and perhaps more worrying more dangerous due to the elevated fault currents in a three phase system.
Consider this. If somehow you cause a fault in your home on a single phase you only have 230V between phase and ground. Do that on a three phase system and you will have up to 415V, depending on how you are wired.
415V is an entirely different ball game in terms of potential damage that can cause!
Continue to use the three phase before your workshop only and stick to standard single phase for your domestics.
scubadog.
I understand the dangers, the potential for damage and I much appreciate your concern - but I don't exactly have a choice.
My first post on the matter maybe wasn't clear enough.
The TP supply incomers/meter/fuses, etc, are in the utility room of the domestic side of things. The photo attached to my second post shows the whole, grim, set-up.
It is also the site of the Three Phase powered central heating system for the domestic side. Moving it somewhere else isn't really an option. It's ducted, blown, warm air. I didn't opt for it, it was here when I bought the place - and it works well.
I'm trying to make the best I can of a less than ideal set-up. I also want to utilise the three phase for my machine tools which will be located apart from the domestic property, about 6 - 8 metres away.
It would be a Very expensive option to have the incomers moved out of the house - and I still need it for the heating anyhow.
PatsPatter
