Hello folks after some advice if you dont mind, I have been given a task at work to cost the infrastructure for 3 phase shore supply sockets for various marine craft and will be utilizing cabling that has been left from recent decommisioned plant.
What I have at my disposal is 2-95mm 4core SWA cables with a length of 245Meters from origin to proposed location for a DB. Cables are in 150mm ducting.
Question is what would be the max current I could expect from this cabling allowing for say a 5% volt drop this would give me an indication as to how many outlets we could have and therefore draw up a spec, I'm not a electrician as you have probably guessed..
Thanks in advance..
Thanks in advance..
