Hi everyone, long time reader, first time poster. Need some advice please.
We have an old heating system - Baxi bermuda back boiler (serviced every year and running fine), hot water tank, pump and 3 port-valve in the airing cupboard.
I believe it's a Y-Plan set up. Couple years ago, upgraded the old programmer to the Hive Dual channel reciver. Installed myself and left the old thermostat in situ and just turned all the way up. I believe there may have been bridging in the old programmer, but I think I removed this based on some advice I found online. Currently, the receiver only has the L, N and a wire into both the HW(On) and CH (ON) both HW&CH Off channels are empty. And of course the earth.
Believe it worked without any trouble, but now I have had to replace my 3 port-valve. I had a Sunvic Duoval (DM5651), mid-position with 5 wires, coloured white, blue, yellow, orange and Earth. I have replaced it with a Drayton (MA1/679-3) Mid- position. Also, with 5 wires, but a grey instead of a yellow. I have tried wiring it in, but have not had any success in getting it to operate as HW only or CH only - I believe the valve is just staying in the mid position. It's brand new, so am sure its my install that is the problem.
I need some advice as it appears that from the fused wiring box, there should be additional wire coming out of port 18 (see pic) and going to the programmer, but this wire isn't present. I'm thinking from looking at the wiring diagrams, that if I connect the wires in the wiring connector box as follows it might solve the issues, but would appreciate some advice please?
Blue - Blue
Orange- Orange
Earth - Earth
Grey (new) - white (old)
White (new) - yellow (old)
Uno Online
Failing that, I'm thinking of completely removing the old room thermostat wiring and believe that to do this, I just disconnect the wires situated at ports 1;2 and 3 in the fused box and remove them.
Keeping me up at night, so I bow to your greater wisdom - please help!
View attachment 213812 View attachment 213813 View attachment 213814 View attachment 213815 View attachment 213816 View attachment 213817 View attachment 213818 View attachment 213819 View attachment 213820
