3 Port valve with 3/4" BSP female thread
16 Sep 2003
Does anyone know where I can get one of these (at a reasonable cost). The existing valve has these fittings with a 22mm to 3/4 adaptor screwed in, so there isn't enough pipe to reach if I replace it with a compression type valve. I did think of using a compression type with a 22mm compression to female adaptor, but they have 3/4" female threads, and 22mm compression is not 3/4" BSP.
Whats the make of the current valve and why are you replacing it?
Repair kits are available for a lot of m/vlvs.
Or, if your wishing to pay a small fortune, try Here :shock:
It was so long ago that I looked at, I can't remember who makes it. Possibly Siemens.
A supplier sent me the Honeywell one which had been shipped direc from Honeywell, marked correctly on the box, but inside was a 22m compression type, and the supplier took ages to respond to queries.
They are expensive at £165 inc vat, but then they want £41 for a synchron motor.
Thanks but their site is practically useless. All I get is a "Session timed out" message when I try to look at a product, and that's in Italian.
I have a few honeywells 3/4bsp in my lockup if your really desperate. PM me if cant sort it - I may be able to help.
Mr. W.
