Morning all,
Hope you are well.
I'll cut straight to the chase, moved into a new (to me) property and have 3 problems with the CH system. My system is:
Glow-worm Ultimate 40FF (will be upgrading at some point in the next few years)
Sealed / Pressurized S Plan+ system
Header Tank with HW Cylinder
Problem 1. CH Pump runs randomly - After checking the boiler manual, the troubleshooting steps point to a new PCB. The boiler isn't smart enough to have a thermo controlled pump overrun, but a timed one. Assume the relay within the PCB is kaput
Problem 2: Loss of pressure - Gradually, over a number of weeks the pressure in the system will drop and I'm topping it up every 2 weeks. I have searched high and low and cannot find any residue of water, so I'm wondering if a faulty pressure release valve on the expansion tank is a possibility? Or maybe a faulty gauge? I have had the CH off completely and the pressure still drops, so it doesn't appear to be on that circuit, or the UFH. Occasionally, the pressure will seem to bomb to 0 instead of a gradual decline.
Problem 3: Luke-warm temp out the boiler when CH is on - This is the one I really want some advice on, so that I have a general idea when the plumber is trying to explain things to me (this is a case of little knowledge is more dangerous than no knowledge, but I just want to be sure I am not taken for new boiler if I don't need one). Anyway, the outlet for the system is hot to the touch when the UFH is on, UFH and HW is on, or just HW. When the CH is on, on its own, or coupled with any of the others,...the outlet pipe is luke-warm at best and takes an age to heat up. Again, the boiler isn't smart enough to know what's calling for it, its just a call for heat so I am wondering what could cause this? I initially thought it could be because the CH circuit size, but the UFH is probably of similar size and that heats up instantly. The heat must be going somewhere as he boiler keeps running and doesn't trip out when it gets to temp. Any ideas?
I also wondered if the problems could be linked in some way? FYI, its only recently had the pressurized S Plan+ upgrade according to my neighbour, and the sellers arent getting back to me with who the original plumber was.
Hopefully someone can shed some light. Sorry for the length, but want to be sure you have all the info.
Much appreciated.
Hope you are well.
Much appreciated.
