32mm connection
6 Mar 2018
Hello
Desperately looking for a 32 mm connector which is internal due to an issue with space .don't mind if it reduces it to 28mm but can't be a standard push on fit which goes on the external pipework. I.was wondering if there was something like the picture which goes inside a 32mm pipe? Thanks in advance
Dave
Not that I`m aware of, firstly is the pipe push fit size pipe or solvent weld plastic, a solvent weld straight connecter is only slightly larger than the pipe.
