hi, i am installing abs solvent weld 32mm pipe through two courses of brickwork..i have managed to borrow a 32mm diamond core drill to do the job...i have now realised that the 32mm pipe is actually a bit bigger than 32mm...therefore making the pipe not able to go through drilled hole, if i kind of jiggle the drill bit around a bit ( as i drill thru or after original hole is cut) will it eventually make the hole bigger?)..i know i should get a bigger drill bit but i will only need to use it once..so any help or advice will be greatly appreciated
