36mm Basin waste pipe
1 Mar 2005
I'm plumbing in my bathroom basin. The waste pipe is 36mm OD, having googled it I think it's pipe intended to be used with solvent weld fittings.
I need to fit an S-trap. Will a 40mm compreesion S-trap fit ok or do I need an adapter bit?
cheers for any replies.
Basin waste should be 1 1/4", same as the pipe so you should need a 1 1/4" (32mm) trap. Compression waste is universal, will fit all plastic waste pipe and majority of other materials.
