I'm just fitting a FCU for my boiler, running a spur of a socket in the same room which is on the ring main. Now on a previous thred someone said to use a 3amp FCU for the boiler. So just been to B&Q and they only had 10amp and 13amp FCU. So i bought a 13amp FCU, which lets you change the fuse. But it doesn't say wether you can put a 3amp into it? Would it be ok? I can't see why it wouldn't but want to check
Cheers in advance.
Cheers in advance.
