4 in 1 tap with water softener??
11 Aug 2020
We are thinking of getting a Quooker or similar 4 in 1 tap to provide hot and cold plus boiling and filtered cold water.
But we also want to install a water softener so are wondering how the two things might work together.
Question: Is it possible to set up the tap so that it gives both (a) soft hot and cold water for washing up and (b) hard water (boiling and filtered cold) for drinking?
Thanks in advance
Yes, it should be, although I'd advise that you soften the supply to the Quooker unit to prevent it scaling up, as that will be the most likely appliance to suffer from scale. There's no reason why you shouldn't consume softened water unless your doctor has told you to stick to a sodium-free diet, but some people prefer the taste of unsoftened water for cold drinking.
