4 outlets 2 cables.
  • Thread starter Thread starter gaswizzard
  • Start date Start date
G
gaswizzard
Have a box on the wall (moved house) that has 4 outlets , these being sat1/sat2/ariel/fm , sat1 gives the sky+ box a signal as does sat2 (all FTA channels) , arial outlet is working for TV (havn't tried FM) , out of the back of box is two cables , how would two cables supply all 4 oulets? , what is the FM socket for? radio?
Not contacted sky yet so card inactive but as said I get all free channels on both sat1 and sat2 , does this mean when I subscribe to sky I will recieve playback/record due to the two sat sockets working? , or are they just linked together in the socket outlet :? ?
Thanks in advance.
two cables should mean two separate satellite feeds, so you will be able to use Sky+ or similar for simultaneous live viewing and recording.
The sat/tv/fm signals are mixed onto one cable, and electronics in the faceplate separate them out to the different sockets.
But you can't [1] get two sat feeds down one cable, so you need two cables.
[1] Special equipment which isn't usually recommended, can.
Simple you get out what you put in. As said to connect to 2 LNB's except for very special can't get two signals down same cable as both on same frequency.
But using filters you can combine and separate SAT, TV, DAB and VHF radio together the separate again. However you will not for example get a DAB signal if there is no aerial feeding it into the cable in the first place. The splitter box tends to be a standard box with all outputs so likely will say FM (or VHF) even where it is not being fed into the coax.
