40mm sink waste pipe connected into square downpipe?
Discussion in 'Plumbing and Central Heating' started by jamiller, 30 Dec 2011.
  1. jamiller
    jamiller
    19 Nov 2005
    166
    Thanks Received:
    Bedfordshire
    Country:
    I have plumbed my old kitchen sink unit into garage. Just through the wall is a convenient plastic square down pipe - which I would like to discharge waste water into. This will save waste pipe running along back of bungalow to kitchen drainand & looking unsightly! Is it ok to do this and if so - how !! Cannot think of suitable connectors available. Thank you. John
  2. muggles
    muggles
    28 Oct 2005
    13,431
    Thanks Received:
    3,104
    Daventry
    Country:
    Sounds like you're intending to run your waste into rainwater, which is not allowed, it must go to a foul drain
  3. Sponsored Links
  4. moggridgeplumbing
    moggridgeplumbing
    1 Mar 2011
    621
    Thanks Received:
    82
    Surrey
    Country:
    You can only do this if you have a combined foul and rainwater drainage system. Assuming the rainwater pipe is connected to the drainage system and not going to a soakaway.
    You will not find a connection for waste pipe to rainwater downpipe. It can be done (Conversion) but would need to be looked into, if it meets regs. ;)
  5. jamiller
    jamiller
    19 Nov 2005
    166
    Thanks Received:
    Bedfordshire
    Country:
    I believe on this 1963 bungalow - it is a combined system. The sink drain runs along the back of the property and on the corner of bungalow/garage (which is where I want to branch in), the rainwater downpipe drops into the same drainage pipe. Thanks for your replies.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
