40mm to 50mm adaptor
11 Jan 2022
I'm fitting the below outside and plan on connecting the branch to an aco drain. I thought the branch would accept a 50mm pipe but it's slightly smaller so Im guessing the max size it takes is 40mm.
Is there any sort of boss adaptor that I can use to upsize from the 40mm branch to a 50mm pipe? I've seen plenty of reducers like below but I need the reverse if that makes sense?
